Thread: Help w/ product selection |
New member Username: M26e4u
Post Number: 2 Registered: May-05
| Posted on Monday, May 16, 2005 - 06:37 pm: |
I am re-doing one of the extra bedrooms in my house and converting it to a massage room for my girlfriend. My plan is to some in-wall speakers. I already stripped the walls down to the studs and insulated them also ran the wire for the speakers. I am now ready for some product selection and need some help. I was going to use 4 in-wall speakers (preferably round and w/ paintable grills) and I needed a simple single cd player for mounting in a closet. Any suggestions would be helpful. thanks |
Silver Member Username: Claudermilk
Post Number: 115 Registered: Sep-04
| Posted on Tuesday, May 17, 2005 - 11:39 am: |
Since the only requirement specified was in-wall, I'll throw Paradigm out there; they have a number of in-wall speakers. I've never listened to any of them however. |
Unregistered guest |
| Posted on Friday, June 03, 2005 - 02:58 am: |
I bought a 2nd Hand Wharfedale speakers model 505.2, rear speakers "Modus" and high range tweeters, I think it is Model 002284 (3 small speakers in one assembly). I would appreciate if someone could suggest A/V Receiver for these set of speakers. Do I need a subwoofer? Any recommendations. |
Silver Member Username: Thx_3417
Bournemouth,
Dorset
United Kingdom
Post Number: 204 Registered: May-05
| Posted on Friday, June 03, 2005 - 03:11 am: |
I wondering how well these in-wall loudspeakers perform without the sub bass turned on, how low will they go and at what sound pressure level and frequency range too are they has good as installing three matching loudspeakers into a THX Baffle wall! P.S. let me know as like to install in-wall for the ceiling Height surround as they will be flush! |
Silver Member Username: Timn8ter
Seattle,
WA
Post Number: 192 Registered: Dec-03
| Posted on Friday, June 03, 2005 - 04:25 pm: |
Being in the UK I'm surprised you haven't checked into EJ Jordan. A pair of JX92S mounted in-wall would work well enough you might go without a sub. http://www.ejjordan.co.uk/index.html
Seattle,
WA
Post Number: 193 Registered: Dec-03
| Posted on Friday, June 03, 2005 - 04:31 pm: |
Here's an example. These people decided to put a grill over the driver but it's not necessary. http://www.creativesound.ca/jordan.html
