Home > Message Board > Home Audio > Speakers > Archive through May 17, 2005 > Normal Tweeters VS Horn Type Tweeters
Author Thread: Normal Tweeters VS Horn Type Tweeters
Ricky L.
Hi, What are the differences between the both? I currently have normal tweeters abd would like to switch to some horn type. What will i notice as in sound? Thanks!
Username: Jan_b_vigne
Dallas, TX
Post Number: 3734
Sorry, Ricky, in three short sentences you have asked questions that have too many answers to fit in a simple post.
Why do you want to change to horn tweeters?
Home > Message Board > Home Audio > Speakers > Archive through May 17, 2005 > Normal Tweeters VS Horn Type Tweeters [ « Previous ] [ Next » ]
