Home > Message Board > Home Audio > Receivers > Archive through June 02, 2005 > Any comments on Klipsch SW10 Subwoofer
Author Thread: Any comments on Klipsch SW10 Subwoofer
Username: Chitown
Post Number: 16
Folks I have found a good deal on this Klipsch Sub at Costco. Any comments good or bad? Klipsch used to be my favorit years ago, but are they still as reputable, or have they gone down like Boston Acoustics? I'm looking mostly for movies and some music.
Is it worth it at $199?
Username: Petergalbraith
Rimouski, Quebec
Post Number: 528
Costco sells Klipsch? I didn't know that...
I've never heard the KSW-10. The newer Sub-10 and Sub-12 are supposed to be okay, but most people aren't too thrilled with the KSW. Can't expect too much for $200...
I think you get more value from Hsu in subs than you do from Klipsch.
Home > Message Board > Home Audio > Receivers > Archive through June 02, 2005 > Any comments on Klipsch SW10 Subwoofer [ « Previous ] [ Next » ]
