Thread: Speaker 80W max vs. Receiver 70W RMS |
Bronze Member Username: Duckmanx
Post Number: 16 Registered: Mar-05
| Posted on Friday, May 13, 2005 - 11:50 am: |
Hi there, This may be a dumb question but... I have a pair of bookshelves I want to use as rears that have a maximum power handling as 80Watts but the Receiver I have's outputs are 75W RMS, so I would not have any issues with the setup of the two correct? Thanks. DuckmanX |
Silver Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 424 Registered: Mar-05
| Posted on Friday, May 13, 2005 - 12:00 pm: |
none whatsoever. Simple universal rule though: as you turn up the volume, as soon as you start hearing distortion that's a signal to back off. Usually what happens is people keep cranking it up and then end up damaging the speakers. |
Post Number: 17 Registered: Mar-05
| Posted on Friday, May 13, 2005 - 12:29 pm: |
Excellent. I want to use them as my rears, should I connect them to the front outputs just to see their limits until cracking or should I break them in first? |
Abubala,
Ababala
The Occupation
Post Number: 425 Registered: Mar-05
| Posted on Friday, May 13, 2005 - 01:30 pm: |
I probably wouldn't bother, rears only do maybe 10% of HT work anyways, they are really an afterthought unless you do multi-channel music with dvd-a/sacd. |
Post Number: 18 Registered: Mar-05
| Posted on Monday, May 16, 2005 - 08:33 pm: |
Thanks Edster. |
