Thread: Sobwoofer or not? |
| Posted on Tuesday, May 10, 2005 - 08:09 am: |
Dear Sir I have a MHC-GN77d in a small sized room withoput subwoofer. I use it to listen to cds and cassettes and view 2 dvds per month. would you recommend a subwoofer with it? will the subwoofer work with cds and/or cassettes? The recommended Sony SA-GN1 subwoofer is not available in Delhi, INDIA. In fact no seperate subwoofer from Sony is available. Can I use any other subwoofer of a good brand? Thanks Best regards Neeraj |
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 642 Registered: Dec-03
| Posted on Sunday, June 12, 2005 - 06:24 pm: |
You can add any powered sub to it - any sony sub will do, like sa-wm250. |
| Posted on Monday, June 13, 2005 - 04:24 am: |
thanx Does it has to be active? what size would you recommend? |
Glendale,
CA
US
Post Number: 648 Registered: Dec-03
| Posted on Monday, June 13, 2005 - 07:16 am: |
An active one will sound better, so i would definitely get an active one. A bigger one sounds better, but I wouldn't put a lot of money into a your present system. A small sub will be ok - my rational is if you are looking for a better sound, I would go with a separate system - separate receiver, cd, speakers. If you just want to add some warmth to your present system, go with a sony sub - the bigger tha better actually, but they cost more naturally. Even the sa-wm 250 is not bad - sony subs are a great value ! Even when you upgrade your audio, I would keep the sub. |
