Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Which one Banana, or straight plug. ...
Author Thread: Which one Banana, or straight plug. Maybe even....
Username: Swwdts
Post Number: 15
Which speaker cable hook up is best.Banana plug,straight pin plug or,raw wire.
Username: Jan_b_vigne
Dallas, TX
Post Number: 3656
Raw wire. The rule is to keep the continuity of the cable intact. Every added connector and connection represents another break in the signal's transmission and if the connection is not gas tight, has a small contact area or is made between dissimilar metals, there is a chance for oxidation and signal loss.
Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Which one Banana, or straight plug. ... [ « Previous ] [ Next » ]
