Home > Message Board > Home Audio > Speakers > Archive through May 17, 2005 > B&w dm 601 with sub.
Author Thread: B&w dm 601 with sub.
Username: Subabu2002
Erode,, Tamil nadu,i...
India
Post Number: 30
hi,
i am looking for front speakers. i read wonder reviews about b&w dm601.does it produce good sound with use of subwoofer?? or 602 will better??
thanks
suresh babu.
Username: Jorge59
Rio de Janeiro
Brasil
B&W DM 600 S3 will not disappoint you and are cheaper than 601/602. Of course it depends on your receiver. For small room you can use sub ASW-300 or ASW-600 for bigger space. If you have a big budget, the B&W 705 is amazing.
Home > Message Board > Home Audio > Speakers > Archive through May 17, 2005 > B&w dm 601 with sub. [ « Previous ] [ Next » ]
