Thread: DVD To MPEG Converter - DVD To Divx,DVD Copy ,DVD Ripper,MPEG Encoding,MPEG Encoder,Dvdhack |
New member Username: Rebecca
Post Number: 3 Registered: 02-2004
| Posted on Tuesday, March 02, 2004 - 09:06 am: |
DVD TO MPEG is a easy to use software to convert a DVD movie to a MPEG file! Just put a DVD disc into the DVD drive,select a target file, click "start" button,you can get the MPEG file in hours. Super easy to use,with DVD TO MPEG,anyone can become a DVD/MPEG expert! Supports all Windows platforms,only a 800K package. Software Features: 1. Super video quality . The video output quality in MPEG format can be as good as the original DVD VIDEO DISC. 2. Multi-format supported . DVD-TO-MPEG can convert DVD MOVIES in different regions to files in MPEG-I or MPEG-II. 3. Perfect compatibility . The files in MPEG-I or MPEG-II format made by DVD-TO-MPEG can be recognized by almost all the video application software and you can edit DVD movies just at your pleasure. 4. Easy to use . Just with one click, everyone can become a master of DVD-TO-MPEG. url:http://www.mp3towav.org/DVD-TO-MPEG/ |
forkart Unregistered guest |
| Posted on Friday, January 07, 2005 - 01:56 pm: |
yasa dvd to mpeg converter is better than this one. http://www.yasasoft.com/yasadvdtompeg/ |
Hotguy_ohio Unregistered guest |
| Posted on Wednesday, November 02, 2005 - 08:52 pm: |
I just downloaded divx dvd burner. Does anyone know how to pull movies from hard drive so i can burn them to dvd? |
