Thread: Acoustic energy evo one |
| Posted on Saturday, April 30, 2005 - 01:25 pm: |
well, are this go well with nad c320bee&c352? or have you another suggestion for that budget. I mostley listen rock, chill out, some jazz, reggea. is it true that I can't get much bass from ae? and is it difficult to run? thanks |
Silver Member Username: Frank_abela
Berkshire
UK
Post Number: 483 Registered: Sep-04
| Posted on Tuesday, May 03, 2005 - 06:23 am: |
Anon the AE will suit that combination fine. It doesn't have big bass but it has good bass. It rocks well and is an involving listen. Place it on a decent stand and it will work fine. Oher competitors for similar money would be the B&W DM303, also very good - and the B&W DM600 which is great fun. Regards, Frank. |
