Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Quick question- adding 2nd subwoofer...
Author Thread: Quick question- adding 2nd subwoofer...
Username: Eddie982
Greetings everyone...i'm new here. I have a quick question:
I have a Sony HT-DDW670 HTIB that came with a 70w powered sub connected thru speaker wire, my receiver has only Speaker-level inputs for the sub.....Now i'm looking to add on a 2nd subwoofer- Sony 8" 100w Subwoofer (SA-WM250) which has both Line-level inputs & Speaker-level inputs. How do i connect the 2nd sub to my system.
Any help will be greatly appreciated!
Username: Eddie982
I just want to know if i can hookup the 2nd sub before spending $89.99. someone told me i can daisy chain it to the rcvr...HOW??? i'm stumped. do i conn the speaker wire from the first sub to the 2nd sub then conn that to the rcvr??
PLZ HELP?
Username: Joe_c
Oakwood, Ga
Post Number: 192
yes that is correct just daisy chain them, or get a bigger sub so that you dont run into phase and room acoustic problems associated with multiple subs.
Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Quick question- adding 2nd subwoofer... [ « Previous ] [ Next » ]
