Thread: Yamaha amp burning smell |
Unregistered guest |
| Posted on Friday, April 29, 2005 - 09:38 am: |
yamaha AX700u has power, but have a burning smell, no sound from anything. Smell is coming from box inside with copper around it(xc281). Is it fried or can it be fixed, a rough idea on parts, price, ease, or if it's worth it. Thanks for any help!! |
New member Username: Pimpzeus
United States
Post Number: 2 Registered: May-05
| Posted on Wednesday, May 18, 2005 - 09:14 am: |
well im sorry to say but u melted it down. u cant really fix it.. how did u hook it up excactly? message me man |
Silver Member Username: Thx_3417
Bournemouth,
Dorset
United Kingdom
Post Number: 213 Registered: May-05
| Posted on Saturday, June 04, 2005 - 09:48 am: |
Oh BUGGER ME! Its toast must have had loose wire that could have possibly crossed over with the output stages. Hope you get your home cinema back up and running soon, and always remember to read the manual before undertaking the task of setting up the home cinema, no mater what even if you’re a professional sound engineer, as some of them around today are total DONKYS COWBOYS and like the… …ABC cinema and the ODEON at Westover Road Bournemouth the sound is to the point of breaking down… ABC and ODEON who have been named and shamed DONKYS you are. DONKEYS MAN!
