| Author | Subject: Tympani Acoustics sub |
Unregistered guest | I found a Tympani Acoustics TPS-15 digitally powered sub-woofer and I would like the specs on it. The speaker itself is fine. Something on the circuit board is broken and wondering if I should bother fixing it or throw it out. I tryed to find information about the company and the sub but had no luck. If you could send me any info on it I would appreciate it. My email is psy8@webtv.net |
Unregistered guest | The amp regularly fails. If you would like to contact the manufacturer they are: Amtec Manufacturing Inc. 6095 Ordan Drive Mississauga Ontario, Canada L5T 2M7 Phone: 905 564-9471 Fax: 905 964--245 |
