Thread: CONNECTING SUBWOOFER |
New member Username: Vblach
North Vancouver,
B. C.
Post Number: 1 Registered: Apr-05
| Posted on Wednesday, April 20, 2005 - 04:08 am: |
I have a Pioneer VSX-454 receiver and I want to connect a Yamaha subwoofer YST-SW015 to it.On the back of the Pioneer it has only one Pre-out for a subwoofer.In the owners manuel for the Yamaha under "connections" it has a note stating that if there is only one Pre-out do not connect the subwoofer. How can I connect it up. Thanks for any help |
Silver Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 417 Registered: Feb-04
| Posted on Monday, April 25, 2005 - 10:37 pm: |
That doesn't make any sense. It has line level connections made for the receiver pre-out. Go ahead and use the RCA input on the sub. |
North Vancouver,
B. C.
Post Number: 2 Registered: Apr-05
| Posted on Wednesday, April 27, 2005 - 02:20 am: |
Thanks Peter,that worked fine. Thanks for the help. Vic Blatchford |
Rimouski,
Quebec
Post Number: 421 Registered: Feb-04
| Posted on Wednesday, April 27, 2005 - 12:27 pm: |
They probable meant that you shouldn't use an all-frequency pre-out like you'd find on a pre-amp to feed an amplifier and then speakers (i.e. do feed the sub anything over 200 Hz or so). What you have done is fine. Glad it worked out for you.
North Vancouver,
B. C.
Post Number: 3 Registered: Apr-05
| Posted on Wednesday, April 27, 2005 - 05:44 pm: |
Thanks again Peter Vic Blatchford |
