Home > Message Board > Home Audio > Preamps > Archive through November 28, 2005 > Mcintosh c-28
Author Thread: Mcintosh c-28
Tran
I will really appreciate it if someone could please provide some input regarding this pre-amp;
Sound characteristics, Compatibility with other brands like NAD or Rotel Amps, etc.
Thanks in advance.
Username: Jan_b_vigne
Dallas, TX
Post Number: 3544
It sounds like music and will mate well with components that do likewise. McIntosh has plenty of reviews on the internet. Mac sound is Mac sound, it sounds like music and that hasn't changed in the last 50 years.
Tran
Thank you very much for your reply.
In your opinion and expertise, would it be a mistake to try to match it with a NAD C-270 Amp?
These might sound like pretty basic questions but since my knowledge in audio is pretty limited I feel like a lucked out when I found this website while navigating through the Internet.
Just like my teachers used to say “The most stupid question is the one you do not ask"
Thanks again
Home > Message Board > Home Audio > Preamps > Archive through November 28, 2005 > Mcintosh c-28 [ « Previous ] [ Next » ]
