Home > Message Board > Home Audio > Phono > Archive through June 06, 2005 > Setting up Project Debut II
Author Thread: Setting up Project Debut II
Username: Bougeard
Limassol
Cyprus
Can some one help? Have set up my Project Debut II, but it keeps sticking or skipping on records which are in mint condition.
Have checked tone arm and rebalanced, also checked anti-skate, but nothing appears to be having any effect. Do I just need to make minor alterations?
Phil
Username: Joe_c
Oakwood, Ga
Post Number: 138
seems like you need a little more weight on the needle
Username: Edison
Glendale, CA
US
Post Number: 621
The weight and the anti-skate has to match, and Joseph is right - you probably want to increase the weight a little at a time, together with anti skating.
If you can't get it to work, take it to the shop where you bought it, and they will set it up for you.
Home > Message Board > Home Audio > Phono > Archive through June 06, 2005 > Setting up Project Debut II [ « Previous ] [ Next » ]
