Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > NAD 3150 or NAD C352?
Author Thread: NAD 3150 or NAD C352?
Username: Stinkpot
Hi all,
I'm looking to upgrade from my onkyo stereo receiver.
Initially, I was planning on buying a NAD C352 (refurb around $400). But now, I have the opportunity to buy a used NAD 3150 that seems to be in good condition for $125.
What would you guys do? Is the old 3150 worth it? I saw that someone mentioned in the 3020 thread that the 3130 was a great amp.
Thanks!
Username: Sun_king
Leeds, West Yorkshire
UK
Post Number: 216
I've certainly mentioned in the past that the 3130 is a great amp and the 3020. I've not heard a 3150 to be honest so can't comment on that particular amp - never even seen one before. Can you try it before you buy? If it's in good condition and the sound appeals then you could save yourself a lot of money buying the cheaper amp. The C352 is a great amp but different to the older ones. If you plan on playing loud I'd go for that as the dynamics and speaker driving power will be spot-on. For quiet to moderate listening levels I don't think you can beat the older Nads - providing they are still serviceable.
Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > NAD 3150 or NAD C352? [ « Previous ] [ Next » ]
