Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Is it a good amp or bad
Author Thread: Is it a good amp or bad
is this boss 4,000 watt amp any good http://discountsjungle.com/bospdpow40wa.html
Username: Subfanatic
Walton, Ky
Post Number: 2044
when it says 1500 watts times two rms its really around 750 watts rms, boss is a terrrible brand, and ibet ifyou get that after about 2 months it will stop working, what kind of power do you need? and what is your price range? what kind of subs do you have?
Username: Shadylimitedx
Pgh, Pa
Usa
Post Number: 14
iam just thinkin about buyin a 12 splw an the boss 4,000 wat amp cause iam not goin 2 spend da much on 1 amp an sub its insane an it will blow so iam just goin 2 stay wit this an da 12 volfenhag in the vented box is so0o damn loud tho iamn a bass headlol an i think its good jls are nice an all but dat much 4 1
Pgh, Pa
Usa
Post Number: 17
an the sub runs at 1/2 ohm or 2 an the amp runs at 1/2
Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Is it a good amp or bad [ « Previous ] [ Next » ]
