Home > Message Board > Home Audio > Amps > Archive through April 28, 2005 > Need help finding the right amp for m...
Author Thread: Need help finding the right amp for my kicker subs
SojiaRaggs9000 Kurk
Hi i got four 15 inch Kicker Comp 03C15 Component Subwoofer, 4 Ohms. the specs are as follows:
* Size: 15", 38.1cm
* Impedance: 4ohms
* Maximum Amplifier Power: 250Watts RMS/
500Watts Peak
* Sensitivity (dB 1W/1M): 89.2
* Frequency Response: 25-500Hz
* Mounting Depth: 7 1/8", 18.1cm
* Mounting Hole Diameter: 13 11/16", 34.8cm
* Min Rec Sealed Box Vol: 2.25 cu. ft, 63.7 liters
* Max Rec Sealed Box Vol: 5 cu. ft, 141.5 liters
* Min Rec Vented Box Vol: 3 cu. ft, 84.9 liters
* Max Rec Vented Box Vol: 4 cu. ft, 113.2 liters
The price of the amp doesn't matter, I'm just trying to get an idea of what to buy.... I kinda know about subs n all that but not really that why I'd really be grateful for the help....
Thanks....
SojiaRaggs9000
Im thinking about getting two BOSS PD-4000 it's 500x2 at 4 ohms what do u guys think?
Username: Artk
Albany, Oregon
Post Number: 201
This is not the car audio section this is home audio. Please move on.
sojiaraggs9000
nice flame thx... neways yeah sorry for that post i did move it by the way....
Home > Message Board > Home Audio > Amps > Archive through April 28, 2005 > Need help finding the right amp for m... [ « Previous ] [ Next » ]
