Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Subwoofer
Author Thread: Subwoofer
Username: Shadylimitedx
Pgh, Pa
Usa
are the 12 splws any good 2200 watts a pieace
Username: Subfanatic
Walton, Ky
Post Number: 2028
what the hell is that, we need make model, like JL w6, ECLIPSE TI, REx.x.x, audiobahn POS, or whatever what is the 12splws
Pgh, Pa
Usa
go here http://a1bigaudio.com/viewItem.asp?idProduct=1062
Pgh, Pa
Usa
Post Number: 8
what r betta the w6 or the w7 or the 18 inch kicker 10,000 watts
Walton, Ky
Post Number: 2035
for sq you would go with the w6v2, for spl you would go with the solox(kicker) its a HUGE pos though cause it is square, and for a mixture the w7, but you can do alot better for the prices and still make it beter, and that sub isnt that good, but i havent personally heard one, but from what it says idk
Home > Message Board > Home Audio > Subwoofers > Archive through May 10, 2005 > Subwoofer [ « Previous ] [ Next » ]
