Home > Message Board > Home Audio > Speakers > Archive through May 17, 2005 > Looking for speakers similar to Marti...
Author Thread: Looking for speakers similar to Martin Logan Montage
Username: Kg2002
I tried them, they are excellent. The only one concern I have is poor bass. Can you recommend anything similar but with better bass? I would appreciate your advice.
Username: Gavincumm
Post Number: 151
the MartinLogan Mosaic will give you all around better sound. Having a planar midrange as well as tweeter, these will sing like you won't believe, ESECIALLY if you like the highs on the montage, which only has a planar tweeter.
The other difference is that the mosaic has an 8 inch woofer, bigger than the twin drivers on the montage. Even though the twins may seem like a better idea, the mosaic has a higher excursion, letting it play deeper and louder.
You will get a MUCH better speaker for only $500 more than the montage
I have heard the Mosaic, and when broken in, it is a mellow, seductive speaker that sucks you in in ways that will be very noticible, ESPECIALLY in imaging.
I have the Mosaics for sale for 1400$ .. Chicago area only ... will deliver or available to pick up.
I bought them a week ago, brand new.
See them at Tweeter for $1995.
Home > Message Board > Home Audio > Speakers > Archive through May 17, 2005 > Looking for speakers similar to Marti... [ « Previous ] [ Next » ]
