Thread: Cambridge soundworks or klipsh |
Silver Member Username: Nnnnick_b
Nc
Usa
Post Number: 301 Registered: Jan-05
| Posted on Saturday, April 02, 2005 - 12:11 pm: |
400 - 500 dollar budget, ne thoughts on which company would be better? Ne suggestions on other brands would be helpful too. thanks |
Nc
Usa
Post Number: 302 Registered: Jan-05
| Posted on Saturday, April 02, 2005 - 12:58 pm: |
bump
Silver Member Username: Stealth_c
Dublin,
CA
Post Number: 145 Registered: Jan-05
| Posted on Saturday, April 02, 2005 - 01:45 pm: |
I personally prefer Cambridge, but Klipsch is a totally different animal. Klipsch a lot of people find fatiguing to listen to (although this is largely because they are amplified poorly), while I find I can listen to my CSW's forever. This is because CSW's are pretty laid back/warm IMO, and they lose some final detail because of it as compared with the Klipsch. Either way, you should listen to both for sure to see which suits your tastes better. Beware the Klipsch-Yamaha Receiver combo from what everyone says though. Athena, Paradigm, Axiom, NHT, Polk, BA, to name a few, all have speakers that are worth an audition. |
Silver Member Username: Gavincumm
Post Number: 146 Registered: Feb-05
| Posted on Saturday, April 02, 2005 - 02:42 pm: |
Klipsch REFERENCE, provided they are amped properly, are a joy to listen to IMHO. However, with a bright sounding amp, they will drill your ears out. TRUST ME, I have been there. I will second the paradigm mention in this particular price range. |
Bronze Member Username: Edster922
Abubala,
Ababala
The Occupation
Post Number: 26 Registered: Mar-05
| Posted on Saturday, April 02, 2005 - 03:00 pm: |
You need to specify: 1. your receiver/amp 2. your listening use (%HT vs. music, music types) 3. your room size |
Bronze Member Username: Jim_mcbob
Post Number: 61 Registered: Nov-04
| Posted on Monday, April 04, 2005 - 03:09 pm: |
I have never owned a more dissapointing piece of audio equipment than Cambridge Soundworks speakers. They are incredibly harsh and fatiguing and, as it turns out, surprisingly inaccurate. (I thought all the vocal performers on The Simpsons had pronounced lisps, until I listened to the show's CD music compilations on a "real" pair of Hi-Fi speakers). Others' opinions will differ, and you should definitely consider all opinions, but my experience with two different CSW speaker systems has convinced me to stay far away from any home audio equipment bearing the CSW logo. |
