Thread: Looking for US$400,00 High Fidelity Mini System |
New member Username: Arlimfilho
Post Number: 1 Registered: 02-2004
| Posted on Monday, February 23, 2004 - 01:34 pm: |
I´d like to buy an high fidelity mini system, i don´t know wich one, i have to choose between Nakamichi SoundSpace 1, Denon D-M50S and Yamaha MCR-E500, i need sugestions! o
Silver Member Username: Edison
Glendale,
CA
US
Post Number: 378 Registered: Dec-03
| Posted on Thursday, March 04, 2004 - 08:14 am: |
Denon got the best review from a British Hifi magazine. I like the Mission speakers it comes with. This one plays DVD as well. http://www.ecost.com/ecost/shop/detail.asp?dpno=394482 |
Bronze Member Username: Avman
Kansas City,
MO
US
Post Number: 19 Registered: Mar-04
| Posted on Thursday, March 04, 2004 - 04:36 pm: |
Nakamichi soundspace one is nice, but I think the yamaha or denon sound more full for about the same price, yamaha and the denon i think sound about the same, but no matter which one you go with remember to upgrade the speaker wire, this will give you a huge diffrence for a small amount of money, you should only need a few feet. I use Monsters Z1 cable, but these is the best i have available in my market too, but i think it gets the job done. hope this helps good luck. |
New member Username: Bryant_hessing
Independence,
MO
Post Number: 1 Registered: Mar-04
| Posted on Friday, March 05, 2004 - 11:44 pm: |
I personally think the Denon is a better looking system than the Yamaha, but that's just my opinion... and I'm a Denon fanboy. Also yeah, upgrading the wire really does make a difference. |
New member Username: Falp
Post Number: 5 Registered: Mar-04
| Posted on Monday, March 15, 2004 - 08:31 am: |
Go for the Denon D-M31, is replaces the M30 and M50 and has got lots of awards. 2nd choice, the Yamaha. |
New member Username: Mark_of_cenla
Plaucheville,
Louisiana
Post Number: 3 Registered: Jun-04
| Posted on Sunday, June 06, 2004 - 09:38 pm: |
I like the Denon and the Yamaha. The best test is to take your own CD and listen to them both. Good luck. |
Unregistered guest |
| Posted on Thursday, June 10, 2004 - 05:06 am: |
Check out Nad's mini-system. The L40 came with PSB Mini Alpha's. The new L70 is 60 watts a side. I'm pretty sure it sounds better than the Denon or Yamaha. But you can see for yourself. Might cost more, but if you consider how you listen to it every day for however long, the however much won't be missed. Best of luck.
Bronze Member Username: Falp
Post Number: 24 Registered: Mar-04
| Posted on Friday, June 11, 2004 - 05:36 am: |
The L70 is a full-size DVD Receiver... no mini system...!!! The L40 is no mini either... For the kind of product there are other options, also from Denon for example.
