Home > Message Board > Home Audio > Amps > Archive through April 28, 2005 > How to install a 12v for remot wire
Author Thread: How to install a 12v for remot wire
Username: Xavierunique
Flint , MI
i was wondering how do you install a 12v for your amp because i do not have a power antenna on my car so the amps comes on with the radio but when i turn the tape deck on the amp goes off so can anbody give me step by step on how to install a switch for this problem and where to run it from the fuse box and back to the radio dont want to have the amp on while the car is off
Username: Touche6784
Post Number: 227
this is the home audio section. try the car audio section.
Home > Message Board > Home Audio > Amps > Archive through April 28, 2005 > How to install a 12v for remot wire [ « Previous ] [ Next » ]
