Home > Message Board > Home Audio > Receivers > Archive through March 25, 2005 > Warm, cold, neutral receivers?
Author Thread: Warm, cold, neutral receivers?
Ok, so is there any difference between the types of receivers. Are there actually any"types" of receivers? Thanks.
Username: Tevo
Chicago, IL
Post Number: 148
These adjectives are used to describe the sound of a particular component.
What is warm sounding to one listener might be neutral to another or vice versa.
Compare receivers on features and power and then listen to them to decide which "type" is best suited for you.
Home > Message Board > Home Audio > Receivers > Archive through March 25, 2005 > Warm, cold, neutral receivers? [ « Previous ] [ Next » ]
