Home > Message Board > Home Audio > Equalizers > Know of an EQ. for adjusting bass rol...
Author Thread: Know of an EQ. for adjusting bass rolloff?
Username: Cheapskate
Post Number: 121
i have a 12" subwoofer (wanted an 8") and would like to find an EQ that will let me roll the lowest octave off.
my sub puts too much deep bass out when all i realy want is 50-80Hz for my tiny minimonitors. deep bass gives me a headache.
i had considered audio control's bass station, but it didn't offer the type os control i'm looking for. my best guess would be to find a parametric EQ, set it's center frequency to 20Hz and adjust the level and band bandwith to get just the amount of rolloff that i want without rattling my walls or neigbors.
anyone know of a CHEAP EQ that's designed just tweaking bass rolloff and not a graphic eq?
Username: Ornlu
Post Number: 24
I was actually wondering about the same thing, but for the opposite usage. Hope someone figures this out.
T2T
I'd look into the Behringer Feedback Destroyer. It has a parametric EQ built into it where you can dial-in the frequency and the adjusted cut. Cost: $100 - 120 (US$$).
Post:
Username: Need to Register?
Password: Forgot Password?
Action: Upload Upload Image
Home > Message Board > Home Audio > Equalizers > Know of an EQ. for adjusting bass rol... [ « Previous ] [ Next » ]
