Thread: B&W Speakers - where to buy? |
| Posted on Saturday, February 21, 2004 - 11:40 am: |
I am looking for a good buy on some B&W VM1's and CCM20 speakers for my system. I like to purchase on the web and need a bargain. |
New member Username: Stone
Post Number: 1 Registered: 12-2003
| Posted on Tuesday, February 24, 2004 - 03:15 pm: |
You can only buy used online. Google Search - you'll find them |
JEFF HALL Unregistered guest |
| Posted on Thursday, February 26, 2004 - 07:59 am: |
I KNOW YOU CAN BUY THEM AT BARNEY MILLERS IN LEXINGTON KY........JEFF |
Bronze Member Username: Heff
Post Number: 73 Registered: 12-2003
| Posted on Thursday, February 26, 2004 - 08:20 am: |
Gee, when I visited a local hi-fi shop to listen to the VM1's for some reason the guys there were not positive about it. They didn't carry it in stock. It was special order and they quoted full SRP. Also they said VM1's were not a popular item when they carried it in stock, and would I be interested in Definitive Technologies? yada yada.... |
Post Number: 3 Registered: 12-2003
| Posted on Thursday, February 26, 2004 - 10:54 am: |
My local dealer doesnt carry the VM1's either, but I have never inquired about them. Overall, they are very high on B&W as a speaker maker. B&W are probably the speaker most bought and sold over the internet used due to there quality of workmanship and good resale value. if you are patient, you can get a nice pair of 602's series 2 or 3 for under 450.00 and a center for 250.00 to 300.00. get some 601's for the rear and you have a pretty good used HT seat up for less than 1000.00 |
New member Username: Bezel
Post Number: 1 Registered: Mar-04
| Posted on Thursday, March 04, 2004 - 04:05 pm: |
Yep, I do not think it's a big deal to find B&W speakers online today. The easiest way - ebay.com, but IMHO you have to spend too much time there to catch your item. I suggest to use hi-fi classified resources: - audiogon.com (most popular one) - audioweb.com (not bad, but not many items there) - audiowatcher.com (very interesting resource that actually helps you to search item using audiogon and other collections) |
