Thread: Cambridge soundworks speaker package |
New member Username: Hacobian
Post Number: 1 Registered: Mar-05
| Posted on Wednesday, March 09, 2005 - 12:57 am: |
Hi guys, What do you think of the cambridge sounworks speaker packages. My budget for speakers is around $1300. Thank you Armand |
Silver Member Username: Stealth_c
Dublin,
CA
Post Number: 109 Registered: Jan-05
| Posted on Wednesday, March 09, 2005 - 01:09 am: |
I personally like Cambridge Soundworks, but there are a lot of choices in that price range to choose from. Make sure to sample a few others before you buy. |
| Posted on Wednesday, March 09, 2005 - 07:33 am: |
Look elsewhere |
| Posted on Thursday, March 10, 2005 - 10:09 am: |
The Newton series are well worth a listen. If you're on a tight budget, they provide excellent bang for the buck value. I suggest that you watch for sales and that you check out their Ebay store, HIFI.COM. They offer b-stock mechandise with full warranty and significant price reductions. I liked what I heard from the T-300 tower and the M-60 bookshelf. The Newton subs are a great deal when they put them up on Ebay. The MC-300 center/fronts go for $125.00 on Ebay and are an incredible value at that price. When matched with a good sub in a moderately sized room, you'll be stunned to get sound of that quality for the price. They're not a flashy brand, but they are produced with solid engineering and design. Definitely worth a listen. |
Bronze Member Username: Jim_mcbob
Post Number: 39 Registered: Nov-04
| Posted on Friday, March 11, 2005 - 06:02 pm: |
Awful. Bought an Ensemble system and inherited M-80s. Both are incredibly harsh, with the Ensembles being painfully fatiguing, even when powered by an older NAD amp. I'd steer clear of CSW products in general--you can do MUCH better for $1300. |
