Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Wiring In Ceiling Questions
Author Thread: Wiring In Ceiling Questions
Username: J3mbeck
Edwardsville, IL
Great forum and thx for the advice in advance.
I'm building a new home and want to install a pair of in-ceiling speakers with volume controls in the kitchen and dining room. Questions is should I use 2 or 4 strand wire? Wire in series or parallel? I also plan on using impedence matching volume controls. Any other suggestions?
Thank again.
btw- My "daily driver" is Cambridge Audio Azur w/ Epos ELS-3's.
J. Vigne
http://www.prillaman.net/ht_info_8-wiring.html
http://hometheater.about.com/od/beforeyoubuy/l/bltips.htm
http://www.hometech.com/audio/
http://www.xantech.com/
See if those links provide answers that arise during the process. I always wire with four conductor cables. If a wire breaks or gets shorted during construction, you have a spare. If it survives intact you can double up the conductors for lower resistance. Series or parallel is a matter of how you want to use the system. Series requires both sets of speakers be on to operate one set. Parallel is an either/or situation. Series will result in higher impedance which is always safer for the amp.
I used to live in an apartment on Main St. in Edwardsville, down by the old Fiat dealership in the '70's. I got an undergrad degree at S.I.U.E. Is Ronnie B's or Vanzo's still in business?
Username: J3mbeck
Edwardsville, IL
Ronnie B's, no. Vanzo's yes. I live near downtwon off St. Louis Street (near the now old High School). Crazy!
Thanks for the links, I'll check them out.
Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Wiring In Ceiling Questions [ « Previous ] [ Next » ]
