Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Ohms and Frequency Response Range
Author Thread: Ohms and Frequency Response Range
Username: Dhearn
Houston, Tx
Usa
I want to do whole house audio. If the speakers that I'm thinking of buying are 8-ohms, how many can I install on one receiver? Also, how important is the frequency response range of speakers? JBL has a pair of 2-way, 8", 120w in-wall spaekers. The freq. response range is 30Hz-20kHz. Am I going wrong by buying these speakers for this type of application? Thanks
J. Vigne
"If the speakers that I'm thinking of buying are 8-ohms, how many can I install on one receiver?"
It depends on how you hook them up.
"how important is the frequency response range of speakers?"
It is not important.
"Am I going wrong by buying these speakers for this type of application?"
Probably not.
Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Ohms and Frequency Response Range [ « Previous ] [ Next » ]
