Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Forgot to remove the bi-wire jumper
Author Thread: Forgot to remove the bi-wire jumper
Username: Petro
I used my speakers now for 3 month in a bi-wire configuration....but with the jumpers on (did not notice the small ink in the manual urging to remove the jumpers before bi-wiring}. Did I damage the speakers? did not notice any difference after removing the jumpers. thanks
Username: Frank_abela
Berkshire
UK
Post Number: 398
It's unlikely that you have damaged the speakers. Interesting that you didn't notice a difference when you removed the links - you should have noticed some difference (good or bad).
So long as the system is working fine, the amp isn't overheating and the sound is not distorting, then there should be no problem.
regards,
Frank.
Username: Petro
Thank you Frank. I will do some more careful listening to try and pick-up differences. initially, i was only worried i damaged the speakers.
Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Forgot to remove the bi-wire jumper [ « Previous ] [ Next » ]
