Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Speakers for Nait 5i, Nait cd5x
Author Thread: Speakers for Nait 5i, Nait cd5x
Username: Charlie494
Hey guys,
Just wandering if anyone can recommend a pair of floorstanding speakers to suit this set up: naim 5i, naim cd5x. My budget is <£1,250 and so far i've tried out some PMC GB1's, which seemed to complement the system quite well but want to know if anyone out there has any other suggestions? I listen to a range of music from ambient electronica to metal via johnny cash.
What do you reckon? What are people with a similar set-up running?
Username: Tevo
Chicago, IL
Post Number: 69
Nice rig.
I think a host of British speakers would go well with those highly regarded components. The Naim 5 is not a behemoth of an integrated so for full dynamic range, I would look at something that has relatively high sensitivity (92+dB).
Cheers.
Username: Frank_abela
Berkshire
UK
Post Number: 390
Charlie
You don't need high sensitivity, the Nait5i is more powerful than many would credit. Apart from the PMCs, here's a few floorstanders in that price range that suit the combination well (I've tried them all bar the EPOS):
Totem Arro - almost made to measure
Dynaudio Audience 62
Dynaudio Audience 72 (just)
EPOS M22.2 (just, also difficult to drive)
Naim Arivas (bang on the top of your budget)
Regards,
Frank.
Username: Cornelius
Post Number: 93
Naim gear is GREAT. I hear the Shahinian Starter is a really good partner to the Naim Nait gear.
Thanks for your help guys.
Think I'll give the arivas a bash.
Home > Message Board > Home Audio > Speakers > Archive through March 17, 2005 > Speakers for Nait 5i, Nait cd5x [ « Previous ] [ Next » ]
