Thread: Help me find a good 4 ohm capable receiver?!? |
Erik Rogers Unregistered guest |
| Posted on Saturday, February 26, 2005 - 01:15 pm: |
From what I have been able to learn so far. Harman Kardon seems to be my best bet. Anyone else have strong opinions on receiver brands or models? I appreciate all the help. |
Bronze Member Username: Tevo
Chicago,
IL
Post Number: 61 Registered: Feb-05
| Posted on Saturday, February 26, 2005 - 01:59 pm: |
Maybe also check into Marantz, NAD & Rotel? |
Silver Member Username: Gavincumm
Post Number: 106 Registered: Feb-05
| Posted on Saturday, February 26, 2005 - 04:54 pm: |
rotel is my favorite of that bunch,and add B&K to that list as well. B&K recievers can produce sound that rivals the best in seperate components, but at a price that comes at seperates, IE in the thousands.
| Posted on Saturday, February 26, 2005 - 09:17 pm: |
Well, I spent 5 hours going around to all the electronics stores I could think of in the Phoenix metro area and ended up at CompUSA. I know who shops at CompUSA for home theater equipment. But I had recently leared that they are no longer going to carry home theater equipment. Because of this they are trying to move all their current stock. Which means great prices. So I ended up with the Harman/Kardon AVR 330. I was able to get it for around $250. And from the little i've tested it so far, I am very pleased. Thanks for all of the suggestions though. Unfortunately, I just can't afford any of the high end receivers listed. |
Bronze Member Username: Jakdaxtersgirl
Post Number: 67 Registered: Feb-05
| Posted on Saturday, February 26, 2005 - 10:16 pm: |
Huh? |
Silver Member Username: Petergalbraith
Rimouski,
Quebec
Post Number: 317 Registered: Feb-04
| Posted on Wednesday, March 02, 2005 - 08:55 pm: |
A h/k avr-330 is a fine choice! I have an avr-325 and I'm very pleased with it. Peter
