Thread: Axiom M3ti's or Paradigm Titans? |
New member Username: Chrismorgan
Post Number: 4 Registered: 02-2004
| Posted on Monday, February 16, 2004 - 01:21 pm: |
Hey folks, would you all suggest Axiom M3ti's or Paradigm Titans for a budget of $250-300? Would you suggest somthing else? Thanks, Chris. P.S. for classical Music |
Silver Member Username: Edison
Post Number: 366 Registered: 12-2003
| Posted on Tuesday, February 17, 2004 - 09:05 am: |
If you like mushy soft sound, go with the Titan. If you like hard sound, Axiom. By the way, this sight has good price on them - www.vertigoonline.com Search for "axiom" in the search box. |
Bronze Member Username: Jonmoon
Post Number: 71 Registered: 12-2003
| Posted on Tuesday, February 17, 2004 - 10:28 am: |
I'm not sure I agree with you James nor do I know what "mushy soft sound" or "hard sound" means. The Paradigms should be had for under $200 and the Axioms for just over $200 so they are pretty similar in price. Here are two review sites for each: www.goodsound.com/equipment/productoftheyear_2001.htm www.hometheaterhifi.com/volume_6_3/paradigm-titan-speakers.html I have the Titans and think they are tight little buggers which deliver nice sound. I have never heard the Axioms so can't compare. There are many forums where these speakers are discussed but the best bet would be to hear both with a receiver similar to what you have at home. Good luck. |
New member Username: Sssand2
Post Number: 10 Registered: 12-2003
| Posted on Tuesday, February 17, 2004 - 10:56 am: |
Let me start by saying that I have not directly compared the Axioms to the Titans. I listened to the Titans at the dealer a while back and am currently audtioning the M3s. That being said, I would say that the Titans are more forward sounding in the mid range while the M3s are more laid back. The M3s are nice speakers but you may not like the mids as well. I'm told that the M2 is more forward from the mids on up but is light on the low end. However, it may be comparable to the Titans. For a bit more over your budget ($328/pr + shipping) you might try the Ascend CBM-170 found at www.ascendacoustics.com. A very neutral speaker that might work well for you. Another possibility is the Athena AS-B1 or B2 which you can get at BestBuy. These are very nice speakers that will fit in your price range. What receiver will you be using to drive these speakers? |
Post Number: 5 Registered: 02-2004
| Posted on Tuesday, February 17, 2004 - 02:32 pm: |
Thanks newbie, probably a Onkyo 8211 as that is what I can afford (around $200) Chris |
Post Number: 368 Registered: 12-2003
| Posted on Wednesday, February 18, 2004 - 07:41 am: |
You can get Onkyo 8511 (100 watts per channel) for the same price if you don't mind refurb - sounds more dynamic and more involving sound. Pretty good smooth sound. I had 8211 but found it to be under powered and not as satisfying. http://www.ecost.com/ecost/shop/detail.asp?dpno=292771 http://www.pcmall.com/pcmall/shop/detail.asp?dpno=292771&store=pcmall&source=zwb 11876&adcampaign=email,zwb11876 This place sells a new one for $199 but is out of stock at the moment - perhaps you can get one when they restock it. |
Post Number: 369 Registered: 12-2003
| Posted on Wednesday, February 18, 2004 - 07:42 am: |
Sorry - not a new one but a refurb at PcMall as well. |
Bronze Member Username: David_r
Post Number: 36 Registered: 12-2003
| Posted on Friday, February 20, 2004 - 09:42 pm: |
http://www.stereophile.com/loudspeakerreviews/104epos/ HAwk recommends taking a look at this also |
K. J. Foster Unregistered guest |
| Posted on Monday, March 01, 2004 - 06:15 pm: |
You can also get a refurb'd TX8511 from direct from Onkyo at http://www.shoponkyo.com/. I have one and I think it sounds great. |
| Posted on Sunday, March 28, 2004 - 12:17 pm: |
hi guys. am in the philippines,i like to buy a axiom grand master or paradigm focus,cc270,adp170 and ps 1000 or ps 1200,which of this two sets is better? the axiom site only offers to u.s and canada,any idea where i can order online? |
Bronze Member Username: Robertinchico
Post Number: 37 Registered: Apr-04
| Posted on Friday, April 23, 2004 - 10:52 pm: |
While assembling an interim system, I relied on some Paradigm website reviews and other consumer input (audioreview.com) to make an uncharacteristically understudied choice on speakers. I grabbed a pair of Paradigm Titans and I didn't like them at all; more accurately I DISLIKED them. Hoping to optimize them, I tried my TWO new different cables on them, Straight Wire Sextet and Symphony, hoping to improve the sound, but it was no use. The bass was lacking, midrange was completely underdeveloped and there was no sparkle or "air" in the highest frequencies. I ended up returning them for the Pardigm Focus, have the Straight Wire Sextet attached and for $400 this is a worthwhile speaker system for the bedroom. The Titans also have the noisiest cabinets I've ever experienced in a speaker. Sonically, I'm afraid they're a waste of money except for the most mundane expectations. |
