Thread: Looking to get a pair of Bookshelf speakers. |
Ryan JJ Unregistered guest |
| Posted on Tuesday, February 22, 2005 - 05:05 pm: |
Hi, I am looking at buying a pair of Bookshelf speakers with a price range of $300-400. I have a small square room (11x11) and would like to use them for music (I like Jazz, Heavy Metal and Piano but play all kinds) but I also love to play videogames. I usually have the volumn low, never cranked. I don't know what sound I am exactly looking for nor do I know the terminology well. If it helps I have a pair of Grado SR60 headphones and I love the sound they produce. I would prefer not to have to buy a sub if possible. I havn't decided on a reciever yet but if I don't need any HT features will an integrated amp work best? |
Gold Member Username: Myrantz
Post Number: 1430 Registered: Aug-04
| Posted on Tuesday, February 22, 2005 - 05:32 pm: |
I recently purchased a pair of B&W DM601 S3's - they are marvellous. For your small room they will provide great depth, accurate imaging and would not need hard work. For your last question: for the same money, yes.
Bronze Member Username: Stealth_c
Dublin,
CA
Post Number: 89 Registered: Jan-05
| Posted on Tuesday, February 22, 2005 - 07:53 pm: |
The Paradigm Mini-Monitor is also something to look into at this price point. |
Bronze Member Username: Gavincumm
Post Number: 90 Registered: Feb-05
| Posted on Tuesday, February 22, 2005 - 09:04 pm: |
take a look at the paradigm focus as well. They have outstanding performance for the money. Go with an integrated, they are better than a reciever in every possible way. |
Silver Member Username: Timn8ter
Seattle,
WA
Post Number: 164 Registered: Dec-03
| Posted on Tuesday, February 22, 2005 - 09:33 pm: |
http://www.us.alegriaaudio.com/Ling.htm |
Dublin,
CA
Post Number: 90 Registered: Jan-05
| Posted on Tuesday, February 22, 2005 - 10:02 pm: |
Tim, how would you compare your speaker performancewise to its established competition like the Mini-Monitor or the NHT SuperZero? |
Dublin,
CA
Post Number: 91 Registered: Jan-05
| Posted on Tuesday, February 22, 2005 - 10:13 pm: |
One other thing, when you state "The patented Adire Audio XBL^2 designed motor.." and give a link to the Adire Audio website, it states that it is patent pending, not patented. |
Seattle,
WA
Post Number: 166 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 12:16 am: |
"Tim, how would you compare your speaker performancewise to its established competition like the Mini-Monitor or the NHT SuperZero?" The extremely flat BL and long throw of the woofer gives it the ability to play surprisingly stout bass while maintaining very good cone control through the mids. No other speaker that I know of in this price range can do this. It's also missing the typical mid-range XO dip common in small bookshelves. "One other thing, when you state "The patented Adire Audio XBL^2 designed motor.." and give a link to the Adire Audio website, it states that it is patent pending, not patented." Thank you. I've made the correction. |
Dublin,
CA
Post Number: 92 Registered: Jan-05
| Posted on Wednesday, February 23, 2005 - 01:07 am: |
Final question (maybe): Why from a business perspective are you making the Ling Single? If you are marketing largely to audiophiles, even those of us with budgets typically want a speaker that can reproduce the highs well. The +/-3dB is notably absent from its frequency response measurements, and there are no nice pretty graphs for potential customers to look at like there is for the Ling Bookshelf. Also, from a production standpoint I imagine it is more costly for you to produce two models instead of one. |
Seattle,
WA
Post Number: 168 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 08:40 am: |
I recently set up a 6.1 system for a customer that the Ling Single worked perfectly for and saved him about $300. Not everyone misses the extreme highs, especially in HT surrounds. I keep a couple on hand just for those occasions. For serious surround sound listeners it's easy enough to use the Ling all the way around. Yes, there is no reponse graph. I should add that to the website. Thank you for your observations. |
Seattle,
WA
Post Number: 169 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 08:52 am: |
In reviewing my response I thought it might be a little vague. The Ling Single was used for the surrounds and rear in the 6.1 system. The Ling was used for the front three. |
| Posted on Wednesday, February 23, 2005 - 09:18 am: |
I see the Ling uses a treated paper cone. How are these for longevity? |
| Posted on Wednesday, February 23, 2005 - 09:55 am: |
I found a couple dealers where I can audition the B&W and Paradigm. What about the Ascend CBM-170, Axiom M3ti, or a NHT? |
Seattle,
WA
Post Number: 170 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 10:51 am: |
"I see the Ling uses a treated paper cone. How are these for longevity?" Treated paper cones have been used for decades (still are) and last a very long time. I recently sold a pair of rebuilt SpeakerLab 7s (over 30 years old)with all the original drivers and they were in perfect condition. Longevity is not really a concern. Of course, anything that is abused will have a short life. Constant exposure to sunlight for example. |
Bronze Member Username: Tevo
Chicago,
IL
Post Number: 48 Registered: Feb-05
| Posted on Wednesday, February 23, 2005 - 11:46 am: |
Which NHT? The SuperAudio SB-series are really good bookshelf speakers but they are somewhat demanding to drive, especially the SB3. If forgoing the subwoofer is a big consideration, the SB3's extend down to 39Hz +/-3dB. They can be had for ~ $500USD but find a dealer to listen if you can. |
edster922 Unregistered guest |
| Posted on Wednesday, February 23, 2005 - 12:26 pm: |
Ryan, I'd go for the Ascend 170s but don't think you'll find really satisfying bass with ANY bookshelf speaker. However, since you say you never crank your music and you list jazz and piano among your top musical preferences, the Ascends would shine in delivering the mids which those two genres have so much of---they're remarkably accurate, clear and smooth sounding! I'd get a sub anyway, even a cheap $200 JBL one can make a huge difference. And budget for a pair of quality speaker stands unless you're wall-mounting the bookshelves---proper elevation does incredible things for small speakers. |
andy11111 Unregistered guest |
| Posted on Wednesday, February 23, 2005 - 05:07 pm: |
I bought a pair of bookshelf speakers in this price range last weekend. I actually want to put them on a bookshelf and this caused problems since many "bookshelf" speakers have rear ports and are designed to sit on stands away from walls. After listening to a several I went for KEF Q1s. I am still satisfied with the choice. |
Dublin,
CA
Post Number: 93 Registered: Jan-05
| Posted on Wednesday, February 23, 2005 - 05:29 pm: |
Andy- An acoustic suspension speaker would solve that problem. |
Seattle,
WA
Post Number: 173 Registered: Dec-03
| Posted on Wednesday, February 23, 2005 - 05:52 pm: |
True, although a small sealed box is going to have a tough time making any respectable bass without some help. The Ling is designed for close wall placement. |
Dublin,
CA
Post Number: 94 Registered: Jan-05
| Posted on Wednesday, February 23, 2005 - 06:05 pm: |
Personally I own the CSW Model Six which is an excellent implementation of an acoustic suspension speaker. The closer to the wall it gets, the better the punch the bass gets. The room makes a huge difference, but for me it goes down to a little under 50Hz, and on the SMR HT review they state it goes down to 40Hz with useable output at 32, which isnt bad at all for a speaker that now costs about 100 bucks. |
| Posted on Wednesday, February 23, 2005 - 06:39 pm: |
Yes. The KEF Q1s came with a bung for the port to tighten and reduce the bass when placed on a bookshelf against a wall. Their recognition that stand and bookshelf locations are different was a positive sign. The non-rectangular shape for spreading cabinet resonances, use of stronger magnets in order to have concentric tweeter and bass for sharp imaging were also positive signs. They also sounded cleanest of the others in the shop around the same price range.
| Posted on Thursday, February 24, 2005 - 11:59 am: |
I am liking the B&W 601 S3's. I was looking at the NAD C320BEE, and I guess I don't know much about integrated amps. Is there way for me to hook up RCA cables to one, or do I need a receiver if I wanted to play my cpu or videogames through my speakers? |
Chicago,
IL
Post Number: 52 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 12:30 pm: |
Yes. An integrated amp is simply a power amplifier + pre-amplifier integrated into a single box. With the C320BEE, you'll have 5 line level inputs + 2 tape loops. Should be plenty for a 2-channel audio system. |
Bronze Member Username: Jim_mcbob
Post Number: 34 Registered: Nov-04
| Posted on Thursday, February 24, 2005 - 04:43 pm: |
NHT SB1 is acoustic suspension design. I was kind of shocked at how good they sounded playing jazz vocals--especially considering that you can pick up a pair in the $225-250 range. Not the most efficient speaker on the shelf, definitely a bit low bass-deficient--but wonderful mid-bass and heart-stopping snare drum. All in all, a lovely-sounding, reasonably priced and attractive speaker. The Ascend CBM-170 are, IMO however, the ne plus ultra in the sub $500 bookshelf category. Rear porting makes placement a teeny bit trickier than acoustic suspension (they work fine with Omnimounts; better still on decent stands). Stealth: we'll just have to agree to disagree on CSW speakers. Ownership of CSW speakers has given me a low opinion of their products, but I concede that everything is subjective. Ryan: RCA away, man. The difference between a receiver and an integrated amp is the presence of a radio tuner. I regularly hook the audio out from my computer to the back of my Reagan era vintage NAD 3155. |
New member Username: Rushwj
Post Number: 8 Registered: Feb-05
| Posted on Thursday, February 24, 2005 - 04:51 pm: |
The Paradigm Mini-Monitors are great! Wonderful speakers for that price range. A must hear. |
Dublin,
CA
Post Number: 95 Registered: Jan-05
| Posted on Thursday, February 24, 2005 - 05:05 pm: |
Jim Bob- No worries, as you say its all subjective. |
| Posted on Friday, February 25, 2005 - 12:16 am: |
Jim-Bob, I was reading one of your older posts that you were able to audition both the Axiom and Ascends with a NAD amp for just music use. What were your thoughts on these? |
| Posted on Sunday, February 27, 2005 - 01:40 pm: |
I listened to the B&W601 and they sounded like there were some problems at the very high end. My dealer did have them fairly loud though (louder than I would ever go). I am looking at the Monitor Audio B2, but their dealer locater is down at the moment. Which bookshelf speakers will have clear highs and play them without a hitch? |
| Posted on Sunday, February 27, 2005 - 02:02 pm: |
> Which bookshelf speakers will have clear highs and play them without a hitch? The Ascends I have (340s) and my friend's (170s) excel at highs and mids, clear w/o being sharp, very accurate and neutral speakers. If you don't like the B&W highs then I definitely wouldn't bother with Klipsch or Axiom. |
Chicago,
IL
Post Number: 66 Registered: Feb-05
| Posted on Sunday, February 27, 2005 - 06:39 pm: |
What kind of problems? Too harsh and forward in the treble? Perhaps you may wish to listen to some speakers with fabric dome tweeters instead- Warfedales, Quads, etc. |
| Posted on Sunday, February 27, 2005 - 09:08 pm: |
"Too harsh and forward in the treble" is a good description for what I was feeling I think. I am going to try and find a place to listen to the MA B2. I'm not sure where I can go to listen to the Wharfedales, or buy them. Which model where you suggesting, the 9.1? |
Chicago,
IL
Post Number: 67 Registered: Feb-05
| Posted on Sunday, February 27, 2005 - 11:07 pm: |
Perhaps the IAG websites for these brands can help you find a dealer: http://www.iagamerica.com/ All three of Warfedale's product lines have models which received favorable press. Pick the one that fits in your budget and go listen. |
| Posted on Tuesday, March 01, 2005 - 04:21 pm: |
Well I have spent some time calling and looking around. I am located in Madison, WI and the only dealers around here are B&W, Paradigm, and Dynaudio. I would like to listen to those Quads and Monitor Audios. I'm not exactly sure what to do in my situation. Chicago is the closest place with those speakers. |
Chicago,
IL
Post Number: 78 Registered: Feb-05
| Posted on Tuesday, March 01, 2005 - 05:10 pm: |
Not having the local dealers to do your auditioning can complicate things. You've got two choices: -roadtrip! -go with what you have locally B&W, Paradigm and Dynaudio aren't exactly bottom of the barrel loudspeakers, if you catch my drift. Truth be told, it is fairly hard to find a dog of a component these days. Especially with recognized brands that have a history of repeatedly building quality components. You'll have to decide for yourself whether the time/expense of scooting everywhere is worth it. If you need references to dealers in Chicago for a specific piece of kit in, drop me a note and I'll try to help ye out. |
