Home > Message Board > Home Audio > Speakers > Archive through February 25, 2005 > Briteness
Author Thread: Briteness
Username: Shokhead
Lakewood, CA
Post Number: 75
How can you get a tad of briteness out of a center speaker. B&W cc6 with a Denon2805 if thats helps.
Username: Timn8ter
Seattle, WA
Post Number: 163
Interesting. I thought that speaker was a bit dull and less crisp than it's precessors. Anyway, some tricks are to hang a piece of tissue paper in front of the tweeter or I've even seen people suspend a ping pong ball in front of it. Another possibility may be to aim the tweeter up or down from the listening position so you're off axis from the tweeter.
Username: Shokhead
Lakewood, CA
Post Number: 76
I'll pass on the paper and ball trick but will play with the aim.
Home > Message Board > Home Audio > Speakers > Archive through February 25, 2005 > Briteness [ « Previous ] [ Next » ]
