Thread: SVSubwoofers |
Bronze Member Username: Shokhead
Lakewood,
CA
Post Number: 73 Registered: Jan-05
| Posted on Tuesday, February 22, 2005 - 11:08 am: |
I'm thinking of replacing my Klipsch KSW300,15" bass reflex tuned port,300 watt continuous into 4 ohms,25-120Hz -/+ 3db,max output 112db with a svsubwoofer 20-39pci. Will this be an upgrade of even or downgrade? |
Bronze Member Username: Jamesp
Mansfield ,
TX
Post Number: 99 Registered: Apr-04
| Posted on Sunday, February 27, 2005 - 10:46 am: |
A pb12-isd/2 or pb12 plus/2 would be a major improvement. 20-39 pci is still an improvement but not so major I don't think it would WOW you. The KSW 300 is a good sub. If you have the space for two subs get the 20-39 pci and try to blend it in with the KSW 300. That would give you comparable performance to a pb12-isd/2. |
Moderator Username: Admin
Post Number: 242 Registered: Dec-03
| Posted on Sunday, February 27, 2005 - 02:16 pm: |
All of the SVS product reviews can be found here: http://search.ecoustics.com/Editorial/Reviews/SVS/
