Thread: Better sound through crossover in sub than LFE on denon |
New member Username: Miso
Slovakia
Post Number: 1 Registered: Feb-05
| Posted on Saturday, February 19, 2005 - 03:45 am: |
my sub sounds better if connected through its crossover than to LFE.does anybody know how cross.in denon avr2800 is set? my guess would be around 80-100hz,which i think is little higher then i would like to,(sub is definitive technology PF15tl+500w,cross.40-150hz/24db)so any idea how to connect it,thank you |
Bronze Member Username: Shokhead
Lakewood,
CA
Post Number: 63 Registered: Jan-05
| Posted on Saturday, February 19, 2005 - 09:53 am: |
LFE is using the reciever x over so go with speakers to sub and sub to reciever to use sub x over. I think thats right. |
Bronze Member Username: Blazer
Post Number: 38 Registered: Feb-04
| Posted on Saturday, February 19, 2005 - 05:17 pm: |
If your receiver sub out is filtered then use the sub's x-over if not use the receiver's. Polk's website has fantastic info on this dilema. |
Lakewood,
CA
Post Number: 68 Registered: Jan-05
| Posted on Saturday, February 19, 2005 - 07:22 pm: |
I belive if you use the LFE,you have to use the recievers x over. |
Slovakia
Post Number: 7 Registered: Feb-05
| Posted on Sunday, February 20, 2005 - 06:59 am: |
ds-and what happens,if i connect it to sub xover,they are going to be both active(i dont think i can switch receivers x over off,or can i?) |
Lakewood,
CA
Post Number: 70 Registered: Jan-05
| Posted on Sunday, February 20, 2005 - 07:47 am: |
LFE bypasses the hpf in the sub. Dont think the 2800 has much if any adjustments to x over in menu. I guess if you sub has more x overs to play with and your not happy the way the 2800 is,run you speakers through the sub and sub to 2800 and use the sub's x over. |
Slovakia
Post Number: 8 Registered: Feb-05
| Posted on Sunday, February 20, 2005 - 04:17 pm: |
...you are right,there is no way i can make any adjustments in 2800,but i am going to try it through the sub(hi-level)and see how is that gonna sound |
