Home > Message Board > Home Audio > Speakers > Archive through February 25, 2005 > Advice for connecting tweeters with m...
Author Thread: Advice for connecting tweeters with mid range
m_att
Hi there,
I have just finished building my own 20W amplifier module from absolute scratch and now I would like some advice on building my own speaker box to go with it.
I just need somone to clarify on how to connect a tweeter with a mid range woofer to the amplifier, I pulled apart my sharp stereo speaker to find a 100V 2.2 micro fared biopolar capisitor connecting in parallel series with the mid range woofer and tweeter then connecting to the stereo. What would this do? Could I do the same when I get my new tweeter and mid range speaker for my new amp? Thanks
Regards Matt
Username: Timn8ter
Seattle, WA
Post Number: 155
A single capacitor is a 1st order high pass filter. This would essentially block lower frequencies from being played on the driver it's connected to. The value of the capacitor determines the roll off frequency. A 1st order filter will roll off at 6db per octave. Whether or not this works for your new drivers is difficult to determine without testing the drivers.
Username: Timn8ter
Seattle, WA
Post Number: 156
As for your Sharp speakers it appears that the woofer is being played full range and the tweeter is being crossed in at around 9kHz.
m_att
Thanks, You have been very helpfull
Username: Timn8ter
Seattle, WA
Post Number: 159
You're welcome. I'm glad the information was useful.
Home > Message Board > Home Audio > Speakers > Archive through February 25, 2005 > Advice for connecting tweeters with m... [ « Previous ] [ Next » ]
