Thread: Paradigm 9se Speakers |
Bronze Member Username: Reggie_lives
Post Number: 14 Registered: Dec-04
| Posted on Thursday, February 17, 2005 - 06:20 pm: |
From my understanding, these are older monitor series speakers? I have a chance to pick up a pair for $250 CDN, and was looking for some input as to whether they would be worth it. I don't know specifically how old the pair I'm thinking of buying are, but from the reviews i've read at AudioReview.com, they seem to be of the 1990's era. Should i shy away from speakers that are that old? Also, from the product information i was able to dig up from paradigm's webpage, it states these speakres are 4 ohms. http://www.paradigm.ca/Website/CommonMain/Archives/Paradigm/5se_7se_9se.pdf My yamaha 5760 receiver has an impedance switch that goes from 8 ohm to 4 ohm. I really have no experience with speakers/receivers, so i want to know if my receiver can power 4ohm speakres, as well as handling 2 pairs of titans (which are 8 ohms) which are being used as a front and rear center channel, and as surrounds. Any experience/input would be greatly appreciated, as well as any type of theoretical explanation that pertains to the impedance of speakers. Thanks
Bronze Member Username: Delsole
Post Number: 12 Registered: Feb-05
| Posted on Thursday, February 17, 2005 - 09:38 pm: |
If i were you i would go for somthing new because they are so old if they break there is no warrenty |
