Thread: Plz help me with this question |
Unregistered guest |
| Posted on Tuesday, February 15, 2005 - 12:10 am: |
i am thinking about buying a 250 watt plate amplifier from partsexpress.com to power a 15 inch audiobahn car subwoofer. i have a very small room(8x8) with no carpet. would this audiobahn subwoofer be good for home audio use. im going to be using it with a home theater reciever but for music only. would a car subwoofer blow up a home subwoofer amplifier? plz help me with this question. the audiobahns power handling is 650 rms, 1300 peak with a single 4ohm voice coil in a sealed box. |
| Posted on Tuesday, February 15, 2005 - 11:50 pm: |
some help plz |
Silver Member Username: Usa2k4
Post Number: 112 Registered: Dec-04
| Posted on Wednesday, February 16, 2005 - 12:02 am: |
All plate amps from partsexpress.com are designed to give max power output @ 4-Ohms so the Audiobahn with a single 4-Ohm voice coil will work OK with that amp, impedance-wise. You may need to consider getting some damping materials for the box as your room lacks the carpet and car subwoofers tend to sound boomy when used at home. |
KEvin N Unregistered guest |
| Posted on Wednesday, February 23, 2005 - 07:20 pm: |
i have two twelve inch pioneer premiers and they rock!!
| Posted on Wednesday, March 02, 2005 - 06:31 am: |
I NEED HELP PLEASE!!!! I need someone to guide me in order to connect the following: SONY STR DE 597 RECEIVER TO TEAC 250w ACTIVE SUB TO MAIN FLOOR STANDING SPEAKERS. THE REST OF THE SPEAKERS(SURROUNDS) ARE PLAYING PERFECTLY. THANX JOHN SACCO CAPE TOWN SOUTH AFRICA. |
