Home > Message Board > Home Audio > Speakers > Archive through February 25, 2005 > Best value bookshelf speakers
Author Thread: Best value bookshelf speakers
Username: Diggs
new here.. i'm looking to complement my budget 5.1 system with a pair of good sounding - but inexpensive - bookshelf speakers for music and tv. i've been looking at the polk rti4 but would like feedback on this and others in that range. i listen mostly to r&b and some jazz so clean sound is more important than volume.
and btw, my receiver is a 5-6 yr old sony es with entry-level polk surrounds & sub.
Username: Dloweman
Post Number: 86
Check out Paradigm, probably the titans will fit the bill
Username: Rd11
Post Number: 20
Athena AS-B2
Username: Kano
Post Number: 328
Ascend Acoustics CBM-170
IMO they're ugly, but hard to beat performance wise for under $400 a pair.
Username: Diggs
been lookin around these forums.. how would the axiom m3ti compare to the paradigm, athena, and ascend?
Username: Gr1m
Post Number: 7
I second the CBM-170s, very accurate and neutral is how I would describe them and at 328/pr they're a steal
Shahrukh
Wharfedale Diamonds. Whether it's 8.1 or 9.1 is up to u to decide.
Username: Project6
Post Number: 2743
I believe the Axiom M3ti is better than the Athena and stages better than the Paradigm and looks better than the Ascends. Soundwise, it is a hard choice to make when comparing to the Ascends. You have to listen yourself and make the choice.
Username: Frank_abela
Berkshire
UK
Post Number: 346
B&W DM600, unless you're looking to replace your current fronts with new speakers. If that's the case, then stick to Polk in order to maintain the same voicing between speakers.
Regards,
Frank.
Username: Timn8ter
Seattle, WA
Post Number: 138
Alegria Audio Ling. $399 per pair. +-3db 50Hz - 20kHz+, real wood veneers. Hard to beat. Plus, if you don't like them after two weeks you can send them back.
http://www.us.alegriaaudio.com/Ling.htm
Username: Dion
I bought a pair of Ling with clear cherry veneer. They're beautiful and sound great. I'm not sending them back!
Username: Project6
Post Number: 2749
Timn8ter,
Did you design those speakers?
Username: Timn8ter
Seattle, WA
Post Number: 144
Yes.
jaeelarr
PSB is the way to go...
edster922
Clean, neutral sound at a bargain price---Ascend Acoustics CBM-170 hands down!
Username: Gavincumm
Post Number: 75
take a look at the Paradigm Focus if you must have clean sound with excellent staging, great bass, and OUTSTANGING MIDS!!!
they are around $320 a pair
gavin
Username: Stealth_c
Dublin, CA
Post Number: 81
Gavin- How would you say they compare with the mini-monitors?
Username: Gavincumm
Post Number: 77
I like the focus almost as well as the minis personally.
The bass in the minis is just a hare tighter, is a few hertz lower, and the highs are ever so slightly cleaner.
They sound very similar. listen to them side by side if you can. You might not even notice a difference.
They are both outstanding, and get a thumbs up from me!
Both speakers have outstanding midrange, have a very smooth, deep soundstage, and will show off your equipment. If you have equipment that adds glare or brightness, these will show you. Unusual for a budget speaker.
Gavin
Richie Rich
Gavin,
Is there a large difference between the Focus and Titan?
Username: Gavincumm
Post Number: 81
yes there is...
I don't really care for the sound of the titans. I can hear the cabinet resonate in the bass frequencies, and that muddies the mids.
The speaker is all around an improvement IMHO.
Username: Rushwj
Post Number: 7
I'd recommend the Paradigm Atoms ($99 each speaker). Just got them for my brother and he loves the clean sound. IMO much better than the polk RT's. Also, at $99 a pop it'd be easy to flush out rears and pick up the matching center all for a descnt price (since you watch tv with them). My brother has a vary large great room and it fills the room w/ sound very well for a small, elegant speaker. good luck.
Username: Gavincumm
Post Number: 85
The Focus is a much better speaker than the atom if you can afford it.
to note... I prefer the atom to the titan. The bass has less boom.
edster922
Tae,
BTW I forgot to mention, whatever speakers you go with, make sure to budget for some quality speaker stands...I find they make a HUGE difference in terms of opening up the sound of bookshelves!
ac4l.com is a great source of quality yet affordable stands; with small bookshelves you can even go with MDF stands without a problem, esp. if you have a subwoofer taking care of the low end for you.
Home > Message Board > Home Audio > Speakers > Archive through February 25, 2005 > Best value bookshelf speakers [ « Previous ] [ Next » ]
