Home > Message Board > Home Audio > CD Players > Archive through May 23, 2005 > Anybody familiar with this player?
Author Thread: Anybody familiar with this player?
mauimusicman
Hi all, just seen this unit called the Onix XCD-88 cd player and it looks an awfull lot like the Music Hall MMF CD-25. In fact, it's based on the same Shanling design as the CD-25. Check it out:
Same Burr-Brown 1732 24-bit/96kHz DAC
Same HDCD decoding chip
Same Philips CDM-12.1 transport controlled by a CD-7mkII servo
Same The OPA 2134 op amps are used for the output stage and low pass filtering
Same Thick brushed-aluminum front plate and solid chassis
Different price tag. Music Hall is $600.00. This one is $399.00. Link below to the site selling it, specs etc. Could be the best deal in digital players as I write this. Anyone got any experience with this unit?
http://www.av123.com/products_product.php?section=processors&product=25.1
Username: Tevo
Chicago, IL
Post Number: 15
From what I can tell, aside from the display, it virtually is a CD 25...
The product description is virtually identical on the Music Hall page.
http://musichallaudio.com/products/products.asp?lookup=cd%2025
mauimusicman
Tevo.....so........for a mere $299.00 it would be a STEAL, no? $100.00 off if your a member of Home Theatre Talk.
Username: Tevo
Chicago, IL
Post Number: 38
If it is indeed a CD-25 with a different display and name on the faceplate, it is indeed, a steal at $299. Even at $399, it would represent quite a value.
Home > Message Board > Home Audio > CD Players > Archive through May 23, 2005 > Anybody familiar with this player? [ « Previous ] [ Next » ]
