Thread: Best speakers under $500???? |
Kimberly Donovan Unregistered guest |
| Posted on Tuesday, February 08, 2005 - 04:13 pm: |
I am looking for a pair of speakers for use with my stereo. Looking for something less then $500 for the pair (this should include suboofer or be a set that does not need one). Prefer something on the smaller size. Suggestions? |
New member Username: Tevo
Chicago, IL,
Illinois
Post Number: 2 Registered: Feb-05
| Posted on Tuesday, February 08, 2005 - 04:48 pm: |
Depends on how much low end extension you like and your listening preferences (material, volume, etc.) I have not found any sub/sat system in the under $500 price range to be satisfying. There are a few bookshelf speakers in this price range that are very, very good PSB Image B25 Epos ELS3 |
| Posted on Tuesday, February 08, 2005 - 04:49 pm: |
In a small to medium room, the Paradigm Monitor 5's (MSRP $579) will give you what you're looking for without a sub. I'm not sure if they fit your definition of "on the smaller side." They're 21" high -- tall enough to include a bass driver along with the mid-range and high frequency driver. Most Paradigm dealers should be willing to come down a little on the price but you may need stands for these speakers. |
