Thread: Damn good receiver !!!!!!! |
| Posted on Wednesday, February 02, 2005 - 08:33 am: |
which one is the best: 1. yamaha RX-V750 2. onkyo TX-SR602 3. marantz SR5500 4. ????? |
Silver Member Username: Frank_abela
Berkshire
UK
Post Number: 313 Registered: Sep-04
| Posted on Wednesday, February 02, 2005 - 08:53 am: |
zyman Try asking this in the Receivers forum... Regards, Frank. |
Silver Member Username: Falp
Portugal
Post Number: 134 Registered: Mar-04
| Posted on Monday, February 07, 2005 - 10:49 am: |
The best? Marantz sr5500! The second? Denon 2105. |
Bronze Member Username: Gavincumm
Post Number: 25 Registered: Feb-05
| Posted on Monday, February 07, 2005 - 10:53 am: |
If you REALLY want the best reciever... throw in B&K, Rotel, NAD and brands like that. I am not sure if that is what you are after though. These will STOMP anything that you have mentioned, but come at a price of entry level seperates. |
Post Number: 26 Registered: Feb-05
| Posted on Monday, February 07, 2005 - 10:54 am: |
What is your budget? |
fiddlyD Unregistered guest |
| Posted on Monday, February 07, 2005 - 12:08 pm: |
which one of those would you recomend for 95% movies??? |
Bronze Member Username: Dloweman
Post Number: 81 Registered: Nov-04
| Posted on Monday, February 07, 2005 - 01:13 pm: |
Definately the yamaha for 95% movies, they have lots of DSP modes and are very good at bringing you into the movie. |
Portugal
Post Number: 136 Registered: Mar-04
| Posted on Friday, February 11, 2005 - 02:24 pm: |
Denon 2105 for 95% movies |
jmgillespie Unregistered guest |
| Posted on Friday, February 11, 2005 - 05:02 pm: |
Go to a ht store and listen to a few different recievers use the same speakers with each reciever and try to get decibal output as close as you can then decide. If you can't tell the difference go with the cheapest one with the features you want. If you can tell a difference look at that recievers brand name entire line and see which one has all the features you want and get that one. It's all up to what you hear. If you can't go and listen to them right next to each other just pick one with all the features you want in your price range and I'm sure you will be happy with it, all the reciever's mentioned so far are respectable brands and are known for quality products. |
