Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through February 13, 2004 > Audio Rack
Author Thread: Audio Rack
Username: Colbytrio
Post Number: 13
Does anyone know where I can find a cheap 4 shelf audio rack? I would like for it to have glass shelves...
I have looked far and wide and eveything is $200 and up. Thats a bit out of my budget!
Thanks!
Username: Gman
Post Number: 188
You probably have to go to Walmart or Target or search Audiogon for a used item. But you better have fairly light components. Good specialty glass that is significantly weight bearing is fairly expensive.
Username: Colbytrio
Post Number: 15
Walmart has an "OK" rack...but it's too high. I need something about 2-3 feet high.
ANd I guess it doesn't have to be glass. I have silver components...would a black rack look funny with them?
Home > Message Board > Home Audio > Receivers > Archives - 2004 > Archive through February 13, 2004 > Audio Rack [ « Previous ] [ Next » ]
