Thread: Speakers for karaoke |
New member Username: Hieu_phan
Post Number: 4 Registered: Dec-03
| Posted on Monday, January 31, 2005 - 05:12 am: |
I'm looking for a pair of speakers for Karaoke. Do you know which are good brands? I have hifi speakers but save them for music listening only for fear of damage when playing karaoke. |
Post Number: 2655 Registered: Dec-03
| Posted on Monday, January 31, 2005 - 08:00 am: |
Bose 802 professional series Electrovoice sx/sb series D.A.S. speakers... Dyanamic or Monitor series Grundorf JBL MP series...not the home speakers. Take your pick. I wouldn't recommend any home speakers for karaoke. I recommend these because they are very sensitive and will not tax your home receiver. Karaoke is a totally different animal. |
Post Number: 6 Registered: Dec-03
| Posted on Monday, January 31, 2005 - 09:06 pm: |
Thanks for your reco. I'm thinking of JBM control CM52 or CM62 in combination with a subbwoofer. Will that help? |
Post Number: 2661 Registered: Dec-03
| Posted on Monday, January 31, 2005 - 10:15 pm: |
Haven't really heard of JBM, so I can't recommend them. But a subwoofer is not recommended for karaoke. |
Post Number: 7 Registered: Dec-03
| Posted on Monday, January 31, 2005 - 10:45 pm: |
Berny Sorry I misspelled it. It's JBL Control CM52 or CM62. Also can you explain why subwoofer is not good for karaoke? Thanks. |
Post Number: 2666 Registered: Dec-03
| Posted on Tuesday, February 01, 2005 - 08:21 am: |
I was referring to the particular models I was recommending. Subwoofers are not needed on these professional speakers. If you are using the JBL control professional series, subwoofers are really not needed, but I suppose if your voice goes below 60Hz you'll need a sub. I suppose you'll need it if the karaoke music you are using have a lot of bass. |
Post Number: 8 Registered: Dec-03
| Posted on Wednesday, February 02, 2005 - 03:52 am: |
Got it. Thanks for your recommendation. |
New member Username: Fable
Post Number: 8 Registered: Jun-04
| Posted on Tuesday, February 15, 2005 - 04:42 pm: |
I would recommend Ascend Acoustics over the JBL. I have Ascend CBM 170 front and CMT center for karaoke and they sound excellent (I have HK 630 receiver). In my other room, I pair Digital Dogg with Aiwa receiver and they sound nothing compare to Ascend (I thought my Dig. Dogg + Aiwa was the best util I bought Ascend). If you buy Ascend, make sure you get the CMT for center as it's really important for karaoke. |
