Thread: Polk Audio Monitor 70 Speakers |
Freckles Unregistered guest |
| Posted on Saturday, January 29, 2005 - 01:51 pm: |
Can I get some comments on these Polk speakers. I will be using them for music and will drive them with a harman/kardon AVR25II amp. My budget is no more than $1000. Thanks
Silver Member Username: Kano
Post Number: 281 Registered: Oct-04
| Posted on Saturday, January 29, 2005 - 03:27 pm: |
Those speakers are Polk's budget line. I would not pay more than $400 for those speakers personally. If you like the Polk sound, I'd recommend the Rti8 speakers. I own these and they are excellent. I would not pay more than $600 for those either though. I can give you more suggestions, but first let me ask you what you will use them for. Are they to fit into a surround set-up or are you buying strictly for 2 channel stereo sound. Also what type of music do you listen to, how much bass are you looking for, and how loud do you like it? |
| Posted on Saturday, January 29, 2005 - 06:27 pm: |
Thanks for the response Kano. I am buying strictly for music, for the living room. The music I like is blues, non-heavy rock, folk, classic vocals; Sinatra, Billie Holiday, Dillon, U-2,Sting, Neil Young, etc. I like a good amount of bass but not booming or house shaking by any means. Thanks for any suggestions. I am looking for quality and would be willing to spend a little more if I need to. Thanks again! |
Post Number: 283 Registered: Oct-04
| Posted on Saturday, January 29, 2005 - 07:21 pm: |
One more question, do you already have a receiver? Which one is it, different speakers sound differently with different receivers. |
Bronze Member Username: Stealth_c
Dublin,
CA
Post Number: 16 Registered: Jan-05
| Posted on Saturday, January 29, 2005 - 10:56 pm: |
For a grand you can definately get a quality speaker, no need to spend more. The Axiom M60ti comes to mind as a fine contender in this price bracket. |
| Posted on Sunday, January 30, 2005 - 12:33 am: |
My receiver is a Harman/Kardon AVR25II. Thanks for the advice!
Dublin,
CA
Post Number: 21 Registered: Jan-05
| Posted on Sunday, January 30, 2005 - 12:39 am: |
Klipsch wouldnt be a half bad choice with HK either. |
