Thread: Decent set of 5.1 speakers in the $1200 range |
Johnny Bravo Unregistered guest |
| Posted on Tuesday, February 10, 2004 - 04:47 pm: |
I'm looking for a decent set of 5.1 speakers to go with the nad 753 reciever I will be purchasing. my room size is 15x20 tile floors seating area is 3feet from the back wall. keep in mind This is for 70%ht 30%audio. my budget is $1200 I wish it was more but thats all I can afford right now. I have a yamaha sw-80 subwoofer now maybe I can intergrate it |
Silver Member Username: Elitefan1
Post Number: 198 Registered: 12-2003
| Posted on Tuesday, February 10, 2004 - 05:18 pm: |
I would recommend a Paradigm system with the Monitor 5 as mains, the cc370 as center and the Mini- Monitor as surrounds. This would be a very nice match with your wonderful NAD receiever and fits your budget. |
| Posted on Wednesday, February 11, 2004 - 10:45 am: |
I just picked up the Mirage Omnisats for $1200 bucks. They are a great set up... check them out here: www.miragespeakers.com |
thearthurclone Unregistered guest |
| Posted on Wednesday, February 11, 2004 - 11:18 am: |
you could get the onix rocket elt set from av123. with the elt sub the package is 999. i picked it up with the ufw-10 sub instead for a price near your full budget. |
Silver Member Username: Gman
Post Number: 183 Registered: 12-2003
| Posted on Wednesday, February 11, 2004 - 12:03 pm: |
I would get 2 pairs of the Ascend Acoustics CBM-170's and their CMT-340C center channel for $858 + $24 shipping. Great speakers---and would be really great with the HSU VTF-2 added, which would bring the cost from Ascend to $1308 + $59 shipping. And you can return them within 30 days if you don't like them. The Ascend's are wonderfully accurate speakers. You should look at their website. |
