Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through March 23, 2004 > Very good imaging speakers
Author Thread: Very good imaging speakers
Username: Kegger
Post Number: 50
ok i have a little different setup i want to try.
i will be biamping using a 2 way electronic xover
i have 4 foot tall cabinets with a 12" driver in
each 1 with the crossover set to 700hz.
what i am looking for are a 2 way set of small
speakers to use as the midrange & tweeter from
the xover at 700hz on up so they do not need to
produce good bass.
i am looking for something with a driver size of like 8" to 5" with very good imaging and can take
a good amount of power.
i'm not looking to spend an arm and a leg if i don't have too , but i really would like to get
a set with excelent imaging that i can use on top
of the cabinets i allready have.
effeciency doesn't really matter because all the channels are adjustable and i can use the mic &
analyser to set the system up.
thanks in advance for any suggestions!
Relevant Product Info
Username: Kegger
Post Number: 51
oh yah this is for a 2 channel audio only system!
Username: Radar_love
very interesting little setup you got there!
i personally have a set of B&W DM 602 Series 3
speakers that have great imaging and are rated
at 100 watts.i love em.
well good luck i hope some others with a little
more experience in this area than me can help!
if hawk see's this he's probably got quite a few he could through at you.
when you get it finished post some results so we
can check it out.
Username: Kegger
Post Number: 54
thanks for the info john.
i went out this last weekend and auditioned some
of the b&w you mentioned they sound nice.
i also liked a pair of focal cobalt like an 806s
or something they sounded ausome but were $1100
a pair at that price i would just buy new towers.
anyone else with oppinions?
Home > Message Board > Home Audio > Speakers > Archives - 2004 > Archive through March 23, 2004 > Very good imaging speakers [ « Previous ] [ Next » ]
