Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > Step up from NAD L40 with Totem Mites
Author Thread: Step up from NAD L40 with Totem Mites
StuartNADfan
About 4 months ago I bought a NAD L40 and a pair of Totem Mites (with a PSB sub). I really like the sound. I listen to a lot of classical CDs and CBC Radio 2 (classical). Basically I'm happy but I'm wondering if a step up would make me even happier? If I plugged the L40 output into a C320BEE, for example, would I notice a difference. Are there better ideas out there?
Thanks.
StuartNADfan
Let me put it a bit differently. If I were to replace the L40 with the C320BEE, C421BEE and C422 and stick with the Totem Mites, would I notice an improvement in sound? Both FM and CD?
Anyone familiar with this gear?
Thanks.
StuartNADfan
Oops. Wrong number. C320BEE, C521BEE and C422.
Home > Message Board > Home Audio > Integrated Amps > Archive through July 25, 2005 > Step up from NAD L40 with Totem Mites [ « Previous ] [ Next » ]
